Scat I-Beam or H-Beam rods?
Old 02-26-2013, 10:41 AM
djoif3's Avatar
Default Scat I-Beam or H-Beam rods?
Im looking into rods and I have found 2 sets from Scat. One is an I-Beam and the other is an H-Beam. Which one should I get? I mean both r forged 4340 and the I beam is about $118 less. ill be pushing maybe 500 HP. Should i save the extra money and just buy the I-Beam?
Old 02-26-2013, 10:47 AM
Fred Flintstone's Avatar
The H-beam would be stronger. But i wouldn't use anything made by scat!
You can pick up a set of Callies compstar's for about the same price. There
quality is light years better than scat.
Old 02-26-2013, 11:15 AM
djoif3's Avatar
Just check the price of Callies H Beam rods, they want 667$ for them. Compared to Scat H beams for 450$ But I do agree that Callies is better then Scat by far.
Old 02-26-2013, 11:23 AM
ironmanLS1's Avatar
I disagree, I have a callies crank and rods in a first gen sbc. I had to go through two cranks to get a good one due to excessive taper on some journals. The rods had to be resized as they were too tight for my comfort.
I think the Scat Pro Comp I beam rod is more than strong enough for most applications, has a good reputation, and is a good value.
Old 02-26-2013, 11:50 AM
Super Hulk Smash
JakeFusion's Avatar
You can get K1 for less than Compstar and the quality is good there. K1 Lightweight H-Beam would be my choice.
Old 02-26-2013, 01:01 PM
KCS
Moderator
KCS's Avatar
LS1Tech 10 Year
The SCAT I Beams are fine. I just built a 377ci LSA with the H Beams and the machining was dead nuts accurate. I'd use them again for sure.
Old 02-26-2013, 01:07 PM
LS1Tech Sponsor
hellbents10's Avatar
The Scat stuff is defiantly better then Eagle, not that bad at all for China.
Old 02-26-2013, 01:27 PM
Stumped1215's Avatar
I ran the scat I-beams and I was surprised how consistent bearings were from one rod to another. I would use them again.
Old 02-26-2013, 05:06 PM
3rdCoastPowerSports's Avatar
I have used the scat I beams on a few builds with good results. They are well made and have a nice price point.
Old 02-26-2013, 05:51 PM
djoif3's Avatar
Thanks everyone, I think im going to buy the Scat I Beams.
Quick Reply: Scat I-Beam or H-Beam rods?
