98 Block
Old 03-02-2013, 02:05 AM
senor_camaro's Avatar
Default 98 Block
I was wondering what piston size I can run, I had the machine shop do a light hone on the cylinder to bring it out to 3.905. Im not sure if I can run some Mahle forged or some stock Hypereutectics, any help would be appreciated since Im not sure what piston size to go with. I called mahle and they said the piston already has clearance built in, im just wondering now.
Old 03-02-2013, 03:07 AM
2000PewterT/A's Avatar
Any piston that is made for a 3.905 bore will work if your bore is 3.905, what pistons just depends on what your plans are for the engine and budget. Wiseco, Diamond are good brands along with Mahle being a more budget friendly option.
Quick Reply: 98 Block
