balancing issue?
balancing issue?
hi, i know a 5.3L, 5.7L, 6.0L, 6.2L use same crank stroke, but combinating a crank from a 6.0L as example with a 5.3L pistons would make balancing issues?
do all cranks weight the same?
thanks.
thanks.
i have 5.3L block, and crank bored to 4.000" with 6.0L pistons and rods, it is breaking trans bellhousing, three bellshousing broken now, i suspect it is about internal balancing issues, i suppost i'm disassembly whole engine...
sounds like you should stay away from the car.
This is the first I have seen of someone claiming 4.0" is OK on a 5.3l block.
You seen to be clueless about the difference between "balance issues" and "balancing issues". You certainly caused "balance issues" but not "balancing issues".
Any shop could have easily rebalanced it if you brought it to them.
"balancing issues" would imply a shop would have had a difficult time doing the work if given the opportunity.
Moderator
The crank definitely needs to be balanced, but considering its a 5.3L and the rods and pistons are from a 6.0L, you'd be better off finding a 6.0L crank that's closer to the right bobweight or at least not need heavy metal.
What made you bore the 5.3L block to a 4" bore? Did you sonic check it?
ok, so i have a "balance issue" prolly caused about mixing up crank and pistons from different engines, i'm taking it to a shop to get it balanced again, or maybe i should look for a 6.0 now... thanks there.
