Ever had vss that wouldn't stay on the seat?
About 500 miles ago I replaced my valve springs and valve stem seals with the platinum dual spring kit from Brian Tooley Racing. Admittedly this was my first time doing vss on this car and the first couple seals probably didn't get pressed down far enough. Today I pulled all of my valve springs to check my vss because I had been smoking under wot and had oil on my plugs. I was expecting to have to fix the first couple seals but instead I found all but about three of my valve stem seals had ridden up on to the valve stems.
Now, like I said, a couple most likely weren't pressed all the way on but after a couple cylinders I got the hang of what I was doing and how to press the seals all the way down on the seat. I used a 12mm 12 point socket, a long rocker bolt with a washer and a pry bar to push the seals on. Any idea why almost all of my valve stem seals came loose? How to I prevent this? Is there a better brand of vss to buy than the ones that come with the BTR springs?
Seems strange as I've never had one come off. Do you for sure have the .505" ID locators? If you somehow ended up with the .565" locators then you'll have issues like that.
Get in touch with me and I'll send you a set of seals gratis. briantooleyracing@gmail.com
Brian
Brian
Brian
Brian
I can not be completely sure as I did not measure them before installing them. I simply compared them to the Patriot locators I removed from my stock 853 heads and they appeared to be the same size. Would the difference have been noticeable to the eye or should I take one off and use a pair of calipers on it?
Yes, that's about the only thing I am very certain of. I do not recall the locators feeling at all loose around the guide when installing them. I'll verify this weekend, maybe even this evening if weather permits, so that we can work with facts instead of out of memory.
