706's milled .030 ???
Old 04-28-2013, 06:16 PM
jaywill's Avatar
Default 706's milled .030 ???
What pushrod will I have to run ? Or the 7.4 will be fine ?
Old 04-28-2013, 07:42 PM
PREDATOR-Z's Avatar
Jaywill, no offense but how the heck do you expect anyone to give you an answer with the amount of info you gave?
There is only one way to find out the right pushrod length, MEASURE
Old 04-28-2013, 09:15 PM
jaywill's Avatar
[QUOTE=PREDATOR-Z;17356044]Jaywill, no offense but how the heck do you expect anyone to give you an answer with the amount of info you gave?
There is only one way to find out the right pushrod length, MEASURE[/QUOTE
no offense 2 u but what! more info do u need..other than the head MILL info and the cam is standard BC ???
Old 04-28-2013, 09:21 PM
03Sssnake's Avatar
^^^You are still guessing. What head gasket are you using, stock valves/valve job, lifters etc all come into play. What is the BC of the cam you are using?
Old 04-28-2013, 09:46 PM
jaywill's Avatar
Never mind i'll measure
Old 04-28-2013, 10:37 PM
LSX Mechanic
Damian's Avatar
A whole heck of a lot, actually.
Camshaft base circle, desired preload, rocker selection, lifter selection, head gasket selection......You know, just to name a few. Your post is extremely vague.
Old 04-29-2013, 08:36 PM
jaywill's Avatar
I got it figured out...thanks
Quick Reply: 706's milled .030 ???
