offset grinding ls1 crank
Old 05-05-2013, 07:45 PM
railrod's Avatar
Default offset grinding ls1 crank
What is everybody's opinion on this..I was told u could go from 3.622 to 3.822 stroke..I know u would have to get new rods..I did a lil math and with a 3.898 bore n 3.822 strike equals 365 CUI..I don't no if it wold cause interference problems but if u use a 6.000 rod u could use stock ls1 Pistons.A 3.822 stroke and 6.0 rod equals same comp height as a5.3 5.7 and 6.0..Seems like b cheap litttitle stroker...Thanks..
Quick Reply: offset grinding ls1 crank
