help calculating head gasket thickness, compression 403
Old 06-12-2013, 01:00 PM
andy9743's Avatar
Default help calculating head gasket thickness, compression 403
hey guys-
looking for some assistance putting together the details for my 403 that is going into my vette. short block details:
LS2 403" Stroker Shortblock
4.000" Stroke CompStar Crankshaft
6.125" CompStar H-Beam Rods w/ARP2000 Hardware
4.005" Bore -28cc Dish Diamond Piston Set
Total Seal Piston Rings w/Steel Top
Melling high volume oil pump
Billet double roll timing set
Comp cam
Spec card #06751604
Grind # LS1 3726/3728
281/285 adv
232/236 @ .050";
.595/.601" lift;
114 degree LSA, ground with a 114 degree intake center line.
i plan to use my c&c-ed 853 casting heads and a ported FAST 90/92...not sure on what thickness headgasket i'm going to need, or if i will need to mill the heads to up compression. shortblock was built for boost but i want to keep the car NA...i got a killer deal on the shortblock.
suggestions? thanks
Old 06-12-2013, 02:04 PM
oakley6575's Avatar
That is going to be a real soggy set up. The cam needs to be advanced a ton to get your dcr up and better to drive. I would use the thinnest head gasket you can find while keeping the quench around .035"-.040". What heads are going on that engine?
Old 06-12-2013, 02:06 PM
andy9743's Avatar
853's that have been cnc-ed...what do you mean by soggy? would a different cam be more beneficial?
Old 06-12-2013, 02:22 PM
oakley6575's Avatar
With that set up, a head gasket isn't going to bump your compression enough to put you in the ball park. With a 66cc combustion chamber, and a .045" thick gasket with a 4.060 bore, your sitting at 9.05:1 static compression and a 6.72:1 dynamic compression. That is crazy low for a NA car
Old 06-12-2013, 02:25 PM
andy9743's Avatar
milling heads is an option correct? what do you mean by advancing the cam to make it more drivable?
Old 06-12-2013, 02:30 PM
The Scammer Hammer
dr_whigham's Avatar
-28cc pistons for an NA car
I'd look at swapping the pistons first.
Old 06-12-2013, 02:35 PM
andy9743's Avatar
What is recomended for pistons? Suggestions on brand? Vendors?
Old 06-12-2013, 03:38 PM
The Scammer Hammer
dr_whigham's Avatar
I'd *personally* go with a -2cc piston, 4.005, either Wiseco or Diamond. Both are shelf pistons.
Vendor: pick your poison. Texas Speed, WS6Store, Vengeance, BrianTooleyRacing.... They're all listed to the right of this paragraph.
Old 06-12-2013, 04:33 PM
PREDATOR-Z's Avatar
With stock chambers 66.67and .052 gaskets,that would get you 11:1
Old 06-12-2013, 04:45 PM
The Scammer Hammer
dr_whigham's Avatar
^^ That's the man I was hoping would show up in here!
OP, listen to Pred-Z... Guy doesn't beat it around the bush and will smack you in the face with fact and reality.
Old 06-12-2013, 05:12 PM
PREDATOR-Z's Avatar
BTW, OP what is your piston to deck height value?
Old 06-13-2013, 07:48 AM
andy9743's Avatar
9.24 piston to deck height i believe. predator-z you have a pm/ thanks guys.
Old 06-13-2013, 07:59 AM
ckpitt55's Avatar
thats not what hes asking for....he's asking for the relative difference between your deck and piston when at TDC. You can backcalculate the deck height once you know this difference since the compression height is known.
Old 06-13-2013, 08:10 AM
andy9743's Avatar
does .005 sound correct?
Old 06-13-2013, 08:58 AM
ckpitt55's Avatar
0.005" out of hole or below the deck surface?
But yes. There's a 0.010" tolerance window on deck height - which is why I was implying that you shouldn't assume that you're dead on at 9.24 (you could be anywhere between 9.235-9.245").
Old 06-13-2013, 10:59 AM
andy9743's Avatar
below deck surface.
Old 06-13-2013, 01:03 PM
PREDATOR-Z's Avatar
below deck surface.
Yes I meant just that. Piston position at TDC with respect to block deck. So are you assuming .005 or is that measured? See that makes a difference in the compression calculations.
IMO -28cc dish is too much for NA setup. -2 cc valve reliefs would be enough.
Cam is a bit small, but would make a nice driver with plenty trq; are you considering a swap?
I would choose more overlap, something around 11* positive to 15* positive.
Old 06-13-2013, 01:13 PM
andy9743's Avatar
thanks for the reply, the engine is at a friends place he measured the .005 for me this am. i would consider a cam change if needed...i 'm only running c&c ported 853's for heads and do not want more cam then the heads can handle. the car will be a driver not a drag car, it'll never see the track.
predator z check your pm's
thanks
Old 06-13-2013, 01:31 PM
andy9743's Avatar
suggestions on what direction to go with pistons? idk if i really need to go with forged pistons for what i'm looking to achieve. whats out there in the 4.005 bore? what is cost effective for a dd type status? i'm not going to race the car, the current crank rods were set up by the po, it's most likely overkill for me. hyperutectic an option in 4.005 bore? thoughts on that? i found some wiseco's for $700 but idk if they would be overkill for my application. i know the c&ced 853's are going to hold me back but that's not the end of the world, i just want a well put together combo that makes respectable power. if i need to change the cam i can, if i need to change the pistons i can, if i can save the cam great...i think the pistons have to be swapped though from what i'm feeling here. intake is a mamo ported FAST unit, with an ls2 tb.
Old 06-14-2013, 11:53 PM
Super Hulk Smash
JakeFusion's Avatar
Mahle or Probe make good priced options in the 4.005" range. Probe I think is like $400 for a set and Mahle is about $600 with rings.
Quick Reply: help calculating head gasket thickness, compression 403
