cam for ai heads
Old 06-23-2013, 05:33 AM
quiet_storm98's Avatar
Default cam for ai heads
Long story short had #7 ring go in my motor and im having a fresh rebuilt shortblock go in so i figure while its out would be the perfect time to upgrade the heads and cam. Im going with ai 226cc ls6 heads and possibly one of their cams as well but was also thinking about possibly going with something like a tick or eps cam. Car is an m6 and will be my daily driver since im being stationed in hawaii and can only have one car shipped also there isn't a track on the island i will be on which sucks. In my other car i had afr 205's and a 230/234 111+2 lsa cam on xfi/xer lobes and it had pretty good street manners for a daily but i really wouldn't go bigger then that.
Old 06-23-2013, 10:20 AM
Jimbo1367's Avatar
You answered your own question. AI spec'ed cam or Martin at Tick Performance.
Old 06-23-2013, 11:14 AM
Darkman's Avatar
Or PatrickG, or Geoff Skinner for an EPS.
Old 06-24-2013, 02:58 PM
I guess what im really wondering is would it be better to go with something like ai's 226/234 cam or ticks sns stage 2 227/235 or maybe get ai to do a 230/234 cam for me
Old 06-24-2013, 05:02 PM
mac62989's Avatar
I would go with them because they know what works best with their heads and since its your DD for awhile, their cams are easy on the valvetrain.
Old 06-25-2013, 10:12 AM
Sales@Tick's Avatar
If I can be of any help let me know.
Old 06-25-2013, 12:15 PM
mchicia1's Avatar
I made great power with their off the shelf 226/230 grind. 460 in an ls1 with their 799s
Old 06-25-2013, 12:23 PM
djfury05's Avatar
I had the AI 226 heads and custom AI cam.. made 475/430 to the rear m6 trans.
Old 06-25-2013, 05:13 PM
Thats good power mchicia for such a small cam. You running a fast intake or have the heads milled or anything?
Djfury i have seen your build thread and the results were impressive with track times to back it up. The cam you used is a little bigger then i want to go though
Old 06-26-2013, 10:37 AM
mchicia1's Avatar
Yes, this was with a fast 90/ls2 throttle body and the heads were milled to 60cc chambers.
If I had to do that setup again, I would mill even more and also use a cometic gasket. It would have hit over 470 with that and that mild cam!
That car ran well too, trapped 125+ on street tires with my crappy driving. Easily was a 128-129+ trap car with a real driver and tires.
Old 06-26-2013, 07:25 PM
Damn that's the type of combo im looking for
Old 06-26-2013, 07:29 PM
KH504's Avatar
EPS 230/238 made 435 rwhp through a auto
Old 06-26-2013, 07:38 PM
Super Hulk Smash
JakeFusion's Avatar
That 230/234 isn't a bad cam. You had a lot of overlap with it on a 111. If you're going with Ai, you could have a similar cam spec'd but you can ease up the LSA a bit and get compression back by milling the heads.
Old 06-27-2013, 06:53 AM
Yeah im thinking of going with a cam that size or the 226/234 cam they offer
Quick Reply: cam for ai heads
