Mahle 41850cp rings.
Old 06-24-2013, 04:30 PM
Justhereforinfo's Avatar
Default Mahle 41850cp rings.
Just to be sure....
The chrome looking ring is the compression (top), and the darker ring with the Napier grove is the second ring, right?
These should be already sized, not file-fit, correct?
Of course I'm about to verify gap since I had a rehone, but just want to be clear I have the rings in the correct spots.
Should these measure out to be within oem ring gap spec, using stock pistons?
Old 06-24-2013, 04:49 PM
I'm getting .020 top and 0.026 bottom.
Top is just out of spec and the bottom is just within. I'm guessing that's from the finish hone.
Quick Reply: Mahle 41850cp rings.
