Lazy lifter or exhaust leak?
My '99 c5 has a new tick. I noticed it while cruising at low rpms with the radio on. I can only hear it in the cabin. It will follow my RPMS from idle up to 2k, but as soon as I hit 2k, the sound immediately disappears.
Here is a video. The sound is noticeable around the 11 second mark when I start revving it.
http://www.youtube.com/watch?v=_HYa4...1&feature=plcp
My 5.3 with 269k in my gmc had a tick similar to that. Sounded like a lifter so I was worried. Well I was watching it idle and saw a spark plug wire dancing around. It was just a loose plug. Needless to say, I was very relieved. Still running strong
Guys, it is an exhaust leak. Right at the 2nd midpipe connection, which is a slip fit. I got the car up in the air and it is leaking so bad that the exhaust gasses fill the bottom of the car and you can see the condensation dripping right out.
I am having this section welded as the only reason it is not one piece already is so you can adjust your catback. So I am going to adjust my exhaust so it is perfect, then mark it and take it to a muffler shop to weld.
I unfortunately have found numerous lifters from different motors not pump/compressing or rebounding like they should,cleaned or not cleaned.
Is something in the oiling system causing the cam and lifters to be starving for oil at some point? Hmmmmmm
