NGK or AUTOLITE??
Old 06-25-2013, 06:27 PM
tin_ss's Avatar
Default NGK or AUTOLITE??
I have a stock ls1 Camaro. all I am going to running is shorty headers. cold air intake and flowmaster exhaust. maybe some time down the road larger throttle body and different gear ratio. I bought 8.5 mm msd ignition wires and autolite rapid fire plugs. should I get the ngk t55 or the rapidfire just fine??
Old 06-25-2013, 09:30 PM
high n dry's Avatar
Ngk tr55
Old 06-25-2013, 09:33 PM
Randolph Ziskey's Avatar
^^^yes
Old 06-25-2013, 10:27 PM
orthopod's Avatar
Went TR55 gapped at 0.045 (per John at TSP) for my bolt-on LS1 and no complaints. Will only change them when I spray in about a year.
Old 06-26-2013, 03:16 PM
sabersaw30's Avatar
I like the ngk also. Just curious has anybody ever run the autolites? I now my turbobuick loved autolites. I would like to try them in a ls1.
Old 06-26-2013, 03:30 PM
Rise of the Phoenix's Avatar
NGK TR55 is what I'm running on my heads/cam WS6. No complaints here.
Old 06-26-2013, 04:28 PM
Randy WS6's Avatar
Im a NGK fan my self.
Old 06-26-2013, 05:57 PM
Blackpanther99's Avatar
NGK ftw! Tr55.
Old 06-27-2013, 09:09 AM
soundengineer's Avatar
autolites are easier to read the plugs...
NGK you have to get it hot enough to burn off the coating before you can read the plugs.
both work well
Old 06-27-2013, 09:15 AM
alexus6798's Avatar
NGK will work fine.
Old 06-27-2013, 09:28 AM
CALL911's Avatar
I have heard people having issues with the NGK's. I personally have used both and although I have never had a problem with NGK's, I prefer Autolites.
Old 06-27-2013, 11:05 AM
mark21742's Avatar
Plain old standard Autolite 103's here in my motor
Old 06-27-2013, 11:15 AM
BIG_MIKE2005's Avatar
Autolite's are all I run in my motor. I have seen enough NGK's in a bucket that were replaced with Autolite's to sway me from spending the extra money on them. I have never had a single issue with a Autolite plug.
Old 06-27-2013, 03:24 PM
Pumba's Avatar
For those of you running the NGK plugs: How is the corrosion on the shell doing?
Old 06-29-2013, 11:40 AM
windmill's Avatar
well im running the autolites 606 plugs love them so far,,
Old 06-29-2013, 01:07 PM
Detoxx03's Avatar
I've always ran NGK plugs and they have been good.
Old 06-29-2013, 01:36 PM
billymgb1000's Avatar
Default yes
I have a 2001 5.3 and I carbed it I am running autolite platinum got about 5000 miles on them and runs great just pulled one just to see looks perfect
Old 06-29-2013, 08:17 PM
Ive never had that issue.
Old 06-29-2013, 08:31 PM
sabersaw30's Avatar
What autolite plug would match a ngk tr6? My car does not like the tr55. I will try some autolites.
Old 07-01-2013, 07:06 AM
If your running N/A like I am I'd just run the Autolite 103's. They are cheap & have never failed me. I know alot of other people who also swear by them & will only run Autolite. they don't get the publicity like NGK, but they perform which is all that matters.
Quick Reply: NGK or AUTOLITE??
