FAST Throttle Body
Old 07-07-2013, 02:58 PM
Matt00's Avatar
Default FAST Throttle Body
Im going to run the FAST truck style 102mm manifold and the fast 102mm throttle body. I am looking at the Big Mouth version and they have the normal Big mouth and the Big mouth with TPS. What is the difference and the advantages/disadvantages of each?
Old 07-09-2013, 09:59 PM
D14HUGGER.ORANGE's Avatar
Depends if your truck/car has a tps sensor on your TB. I would consider nick William 102 throttle body ftw!
Old 07-10-2013, 01:29 AM
Matt00's Avatar
Haven't heard anything on them but I will read up on em for sure!!
Old 07-10-2013, 08:44 AM
Super Hulk Smash
JakeFusion's Avatar
I'd do the FAST over the NW in the 102.
102s have low-speed problems due to the amount of air they let in. You can tune around it for low-speed driving and idle, but the problem is the amount of air goes from nothing to a lot very quickly with just a very small amount of throttle. That fine tuning is very tough to get perfect. But that's why when you crack the throttle... it's damn near instantaneous throttle response.
FAST actually created an area of turbulence at the bottom of the TB that slows the air down when the blade is partially cracked. This allows for fine tunability of low speed and idle air characteristics.
That will save you or your tuner a lot of time on the tune and ultimately make the car behave much more like stock with the added bonus of excellent tip-in throttle response.
Here is a pic of it on my FAST TB.
Old 07-11-2013, 01:09 AM
Matt00's Avatar
OK thanks for the pic. Ive heard alot of good things about FAST from alot of ppl. Thats probably who I will go with when the time comes.
Old 07-11-2013, 01:10 AM
Matt00's Avatar
Ill be running the truck style FAST 102 manifold with it ported.
Old 07-11-2013, 01:36 AM
Burken01's Avatar
In the past the fast 102 TB were giving tuners problems, idk how but I remember a bunch of threads for it to stick to my memory..
I think any good tuner should be able to account for this regardless
Old 07-11-2013, 01:43 AM
Matt00's Avatar
I agree with you on that!
Old 07-11-2013, 02:13 AM
lemons12's Avatar
Jake, thank you for that info.. That is a first for me.
Old 07-11-2013, 08:29 AM
Super Hulk Smash
JakeFusion's Avatar
You know me. I try to find out everything I can then make a sensible decision.
Old 07-11-2013, 10:48 AM
ckpitt55's Avatar
in addition to not having the "speed bumps", the nw tb's also leak (substantially) through the throttle blade roller bearings that may or may not cause you some additional tuning issues to the ones typically associated with a 102.
get the fast.
BTW - "TPS" = throttle position sensor. If you still have the one from your stock tb then you can reuse it on the fast, drops right in. if you sold or misplaced it then you need a new one.
Old 07-11-2013, 12:13 PM
Matt00's Avatar
Ya I figured that out. Mind went blank for a while lol.
Old 07-11-2013, 12:15 PM
Matt00's Avatar
And Jake I'm with you I am doing all I can to research every part that Im thinking of buying ahead of time so Im not dissappointed in the long run. How much did the LS6 heads help you out on your build?
Old 07-11-2013, 01:23 PM
mkvamso's Avatar
The older fast tbs were the ones people had trouble with
A buddy of mine has one on his car and its been a huge pain in the *** tuning it
I dont think the newer ones have the same problems
Old 07-11-2013, 07:10 PM
Matt00's Avatar
Good to hear!
Old 07-11-2013, 08:37 PM
Super Hulk Smash
JakeFusion's Avatar
The FAST 90s were problem children. They fixed the issues with the FAST 92 and the FAST 102 is even more refined.
Old 07-11-2013, 09:12 PM
Matt00's Avatar
Thanks for clearing that up for us.
Old 07-11-2013, 09:15 PM
Matt00's Avatar
Would it be worth swapping my heads with a ls6 set?
Old 07-11-2013, 11:21 PM
lookin4aTA's Avatar
Get the the FAST TB. We didn't have hardly any trouble with mine when we started tuning it. we shall see how the fine tuning goes next week for the finishing touches.
Old 07-12-2013, 12:09 AM
Matt00's Avatar
Ok let us know how it goes!!
Quick Reply: FAST Throttle Body
