Where to get rocker arm shims?
In the process of shimming my rocker arms for proper wipe pattern - I need somewhere north of .140" but have been unable to find any shims of that thickness with a reasonable tolerance attached to it.
Mcmaster has .125"s but at that thickness the tolerance is +/- 0.013" ... pretty unacceptable when you're trying to be consistent arm to arm. I could sit there and juggle shims or sand them until I get uniform thickness between rocker pairs, but really have no desire to do so if I can order them in a usable form. Tolerances on thinner shims are much better, but I don't like the idea of stacking oodles of shim to get the thickness I need.
Really just looking to make life easier for myself here - rocker arm shim affects push rod length, which has tolerances of their own attached. The better I can manage the tolerances of the parts I actually have control over, the easier it will be to consistently hit 0.025" - 0.030" lifter preload (I only have a 0.005" window to work with).
Any ideas?
Any ideas?
I bought them from McMaster (0.125", part #3088A820) and checked them when the arrived. McMaster advertised the thickness as +/- 0.003" so not sure why your are finding such a large tolerance. I picked the sixteen closest in thickness, but in all honesty they were pretty consistent. If you stacked mine with a 0.015", you would get your 0.140" thick with a tolerance of +/-0.004".
Have you tried the wipe with 1/8" so that a single shim will work?
Also, I had to really clear out the inside of the valve covers, including the baffles and the coil mounting hole bosses, because of these thick shims and needed longer bolts that wouldn't penetrate into the intake port.
probably because i was looking at stainless steel....the tolerances on the regular steel are +/-0.003" as you said. i don't know why I was under the impression you went with stainless.....so maybe I'll try those.
when checking the wipe though, I was just stacking the washers provided with the arms because I didn't have anything else on hand. since I can only increment in 0.04x" or so at the moment, it doesnt allow me much finesse on creeping up on the optimum height. the best wipe I was able to get was using 3 of the provided washers under the pedestal, totaling 0.140". It looks to me like the pattern could creep a little more towards the middle of the valve....what do you think? (side towards the bottom is the intake side of the head). I may order a variety of checker shims that I can stack up in a more precise combination to really try and zero this thing in. right now it feels like trying to adjust a fine watch with a sledgehammer
also as far as valve cover clearancing....are you running the thicker yella terra valve cover gaskets or stock ones?
I am running stock gaskets. From the photo, the pattern is very narrow but looks to be a tad towards the intake side. You may end up with a very narrow pattern in the end.
What I did to get the thickness was use some regular washers I had laying around to play with the thickness. Once I was happy with the result, I measured the total stack height. You may be able to go to a hardware store and pick up some washers. Fender washers are typically thinner but you need to drill out the center and clean up the hole if you go that route.
You bought paper machet YT's?
Sorry, couldn't resist.
I have milled 205's, and the shims provided worked fine. You and Bob seem to need thicker shims. I just find that interesting.
I ended up with 7.450" PR's and got a nice narrow pattern nearly centered. Of course with the short travel lifters you need to nail it pretty close.
When I put the new rockers on this weekend, I think I'll rig up a dial indicator and do a direct measurement of the actual pre-load I ended up with.
Ron
Ron
If you are dead set on using a single shim, you could always buy http://www.mcmaster.com/#3088a88/=np5o5i this shim and mill them down to your desired thickness. Stainless probably isn't necessary since the chance of non-coated steel rusting in that oily of an environment is nill to none. Or just do what was mentioned above and stack shims to get your desired thickness.
edit: a quick google search and I found this company. http://www.phoenixspecialty.com/products/shims/ give them a call maybe they could help you out.
And yeah I came across phoenix, not sure what a quote would be for something like this but it'd be cheaper and faster to make them myself I'd imagine.
You could actually make one shim per pair with 2 holes ground flat to your desired height.
That would be cool.
I just replaced my rockers last night, so I got to see the pattern on all the valves. Looks just like yours. Although, you can tell the valves spin from time to time.
Ron
That would be cool.
Ron
I used the shims supplied with the YT rockers. Heads are AFR 205.
I set them up on the bench just like you did.
My cam is an EPS custom, LS7 lifters and the pushrods ended up at 7.450 (off the shelf Trick Flow) to get approx .050" preload.
I should mention that my heads were used, and the valve stem tips were a little rough so my machinest did a cleanup cut on them. Not sure how much. Prev owner ran high lift and stock rockers it appeared.
Ron
Ron
I checked one head last night, they all seemed to like .130" shim. 0.125" was passable but the extra .005" seemed to center the wipe up a bit better. going to check the other head tonight probably but I'm not expecting much to be different. probably just going to end up stacking a .005" on top of the .125" shim and calling it a day - I'm going to measure each shim height and ensure that they're close but I don't think there's much to be gained from machining the finished shims from scratch.
