Katech Piston Squirters for RHS Blocks now available
We now have Katech piston squirter in stock for RHS blocks. The RHS block is a little different than the GM blocks. There is only one oil galley to access so we needed to make a dual-nozzle squirter. The crossover tube is clearly visible but you have to look closely to see the hole in the squirter that jets oil to the closer bank. These have LS9 squirter bolts in them so they turn off at idle just like the ZR1. Four are required per engine and the machining is already done on the RHS block.
http://store.katechengines.com/katec...lock-p392.aspx
