Are roller rockers worth it?
Old 08-23-2013, 08:02 PM
Ws6power1's Avatar
Question Are roller rockers worth it?
I've got a pair of 317's Ive had built with double springs and bigger valves for a boosted motor. Are roller rockers worth it or should I just use the stockers? I see there are roller rockers on ebay for a couple hundred. Does anyone use them or are they junk? Thanks guys
Old 08-23-2013, 09:03 PM
usafws6's Avatar
aluminum or steel? ive broken aftermarket aluminum ones with a relatively low lift cam. and if your getting them off ebay im assuming they're a cheap no name brand.
Old 08-24-2013, 12:02 AM
Ws6power1's Avatar
For around 200 dollars there are aluminum and stainless stell on ebay. Yeah they are basically no name. If I do use stockers do you think I should use the ls1 or lq4 rockers?
Old 08-24-2013, 10:09 AM
wildcamaro's Avatar
They are both the same...save yourself the headache of roller rockers and just upgrade your stock ones...summit sells Comp cams upgrade trunnion kit
Quick Reply: Are roller rockers worth it?
