Any advice? Broken exhaust bolt.
Old 10-15-2013, 02:30 PM
X-Bomb Racing's Avatar
Default Any advice? Broken exhaust bolt.
I have a broken exhaust bolt and its sunk down in the hole just enough that you cant get a hold of it. I started by drilling a small hole in the center and was using a ez out kit from snap on with the proper drill bits. Bad thing is the ez out snapped the end off in the hole. Tried drilling again and of course they are hardened. Anyone got any tricks to getting these bolt out of the head?? Thanks
Old 10-15-2013, 02:43 PM
Bowtie316's Avatar
Find a washer with a hole the same size as the broken bolt, weld the washer to the broken bolt, weld a nut to the washer, remove with wrench.
Old 10-15-2013, 03:26 PM
Great idea. Thanks! I had thought about welding a nut on but figured it wouldn't hold good because of depth in the nut and getting good penetration. Sometimes the simplest fix don't even cross my mind lol Thanks again.
Old 10-15-2013, 10:10 PM
2000PewterT/A's Avatar
Done this a few times to remove some studs on some equipment, works great if I can't get a good bite on it with a vise grip.
Quick Reply: Any advice? Broken exhaust bolt.
