Oil pump swap questions
Old 11-02-2013, 02:48 PM
fruitsalad's Avatar
Exclamation Oil pump swap questions
While changing the oil pump, I've read that you only replace the front crank seal, GM (dealer) part no. 12585673, which I have. Do I/can I/would I want to reuse the timing cover gasket?
What brand and type of RTV should I be using for the timing cover to oil pan seal?
It seemed to me like I had more questions but that's all I can think of for now. Any help is much appreciated!!
Old 11-02-2013, 06:33 PM
The Scammer Hammer
dr_whigham's Avatar
Originally Posted by fruitsalad
While changing the oil pump, I've read that you only replace the front crank seal, GM (dealer) part no. 12585673, which I have. Do I/can I/would I want to reuse the timing cover gasket? What brand and type of RTV should I be using for the timing cover to oil pan seal? It seemed to me like I had more questions but that's all I can think of for now. Any help is much appreciated!!
Grab a new cover seal as well.
RTV - Ultra Black.
Don't forget the new O-Ring for the oil pickup tube.
Any other questions throw them up. There's more than enough knowledge on this board to help with anything you could possibly think of.
Old 11-02-2013, 07:59 PM
01ssreda4's Avatar
Ultra black has never let me down.
Old 11-02-2013, 08:55 PM
That's MISTER MODERATOR
Paul Bell's Avatar
I like Ultra Blue. It's blue so it's got to be better!
Old 11-02-2013, 10:29 PM
Super Hulk Smash
JakeFusion's Avatar
I used Red. Will that be a problem? Also, the other advice is all solid.
Btw Dave I texted you. Are you out on the rig?
Old 11-03-2013, 12:09 AM
Paul Bell's Avatar
Any Permatex Ultra is good.
Old 11-03-2013, 12:24 AM
Super Hulk Smash
JakeFusion's Avatar
It's Permatex high temp RTV. I saw the black but I picked up the red for some reason. Oh well.
Old 11-03-2013, 07:51 AM
The Scammer Hammer
dr_whigham's Avatar
Yeah. I'm out till Tuesday. Once I hit the beach my phone normally goes ballistic for a solid 5 minutes, lol.
The black is EXTREMEMLY oil resistant, and what I've used for both the front and rear covers, as well as rocker arm bolts. This is of course, if your rocker holes are no longer blind.
Old 11-03-2013, 10:17 AM
fruitsalad's Avatar
Thanks guys. Picking up a tube of Ultra Black. Got my new car style o-ring.
Old 11-16-2013, 02:29 PM
fruitsalad's Avatar
Bump! I'm moving really really slowly on this.
I can't get the crank pulley bolt off. (M6 car.) I have a 25-inch breaker bar and all it's doing is turning the crank. I have the car in 4th BUT my parking brake cable snapped off at the handle so I can't set it. The car isn't moving at all because my wheels are nice and chocked, but I'm lost as to how to get the crank to stop turning while I'm trying to loosen it.
I should be going lefty loosey right? Is the lack of parking brake what's killing me on this?
Old 11-16-2013, 02:45 PM
97FormulaWS-6's Avatar
Location: Land of the Mormon's although I'm not one of them
It's on with a 240Lb-ft of torque... they're not fun to break loose. I suggest an Impact; that's always worked the best for me. There are other ways... just search how to remove the balancer bolt.
Old 11-16-2013, 03:45 PM
fruitsalad's Avatar
I can probably wrench it off if I can get it to stop moving. I just need to know how to stop the rotation.
I'm just putting the breaker bar on it with a 24mm socket and trying to turn counterclockwise. It just spins though.
Old 11-16-2013, 04:36 PM
Cajun ELESS-ONE's Avatar
have u tried to lock the flywheel itself?
Old 11-16-2013, 05:35 PM
fruitsalad's Avatar
I haven't. I've heard I should stick a flathead or a dowel pin or something in it to lock it.
What else do I need to disassemble to lock it and how do I make sure it doesn't distort the flywheel? That's no doubt what I need to do to stop it rotating.
Old 11-16-2013, 09:11 PM
The Scammer Hammer
dr_whigham's Avatar
All I can give is MY experience. My car was jacked up on jack stands i forget how much.
I used a piece of the jack assembly from my (at the time) 2004 escalade. The part that goes TO the jack itself, to aid in turning. I put that on a tooth, touching the floor of the garage, and proceeded to "dead lift" the wrench and broke it free that way.
It didn't" feel" a full 240, that's for sure.
Old 11-16-2013, 10:15 PM
Super Hulk Smash
JakeFusion's Avatar
I hit it with an impact and it laughed at me. So I pulled out my 24" breaker bar (while it was on the engine stand mind you) and broke it loose. I put a couple of the old head bolts in the flexplate and wedged them against the block to keep it from turning. It seems steady pressure works best.
Old 11-17-2013, 03:36 AM
Quick Ranger's Avatar
Mine came off no problem with an impact. Now re-installing isn't gonna be that easy. I will need to get one of the tools to hold the flywheel.
Old 11-17-2013, 05:02 AM
Ronny_02_WS6's Avatar
A long breaker bar and a cheater pipe worked for me, I had it in 4th gear and e-brake all the way up.
Felpro Has a complete gasket kit, I have used this kit in 2 TA's and it's awesome!!!
Here's the link: http://www.summitracing.com/parts/fel-tcs45993
Also, I used LS7 bolt to install the balancer, is the cheapest and easy way since it's longer than the ls1 so the balancer goes in.
Old 11-17-2013, 06:25 AM
eseibel67's Avatar
Put it in 6th gear.
Breaker bar with an extention pipe has more twisting power than your average 1/2" impact gun.
Old 11-17-2013, 03:06 PM
65rambler's Avatar
Kent moore makes a tool that goes in place of starter and holds flex plate.
Quick Reply: Oil pump swap questions
