O-ring issue on LM7
Old 11-26-2013, 01:23 PM
FormulaColy's Avatar
Default O-ring issue on LM7
What color oring should be used on an LM7 block using an LS1 oil pan and pickup tube?
Old 11-26-2013, 02:22 PM
Burken01's Avatar
Depends on what oil pump? Ls1 I assume?
I copied and pasted this from an old thread
They are color coded for a reason, like stated above, if the pickup tube has a recessed area where the o-ring goes you need the thicker RED o-ring.
GM Oil Pick-Up Tube O-Ring (1st Design)
12557752
BLUE SEAL
Specifics:
* Oil Pick-Up Tube O-Ring ea.
* Chevy/GMC Pick-Up (1999-2000 LS V8) 1st design
* F-Body (1998-2002)
* Cadillac CTS-V (2004-2007)
* Corvette (1997-2008)
* Thickness = 3.55mm (0.140")
ID = 23.60mm (0.930")
GM Oil Pick-Up Tube O-Ring (2nd Design)
12584922
RED SEAL
Specifics:
* Chevy/GMC Pick-Up (1999-2000 LS V8 engines with 2nd design pick-up tube)
* Trailblazer (2003-2008 With LS V8 engine)
* Hummer H2 (2003-2008)
* Hummer H3 (2008 With LS V8 engine)
* Chevy/GMC Pick-Up (2001-2008 LS V8 engines)
* W- Body (2006-2008 With LS V8 engine - Impala, Lacrosse, Grand Prix)
* Thickness = 4.20mm (0.165")
ID = 20.69mm (0.815")
Old 11-26-2013, 02:27 PM
using the lm7 oil pump since the motor is already together. its just going on the car to get it running and moving around before the turbo gets here. i will be replacing the oil pump before the build so this is just a momentary thing
Old 11-26-2013, 02:28 PM
Burken01's Avatar
Sounds like you just need the blue seal above
Quick Reply: O-ring issue on LM7
