Improved Racing Crank Scrapers
Old 04-30-2014, 08:04 PM
studderin's Avatar
These work!!!!
done it back to back on the dyno (dropped pan on dyno, put hot oil back in)
Gained More then improved listed.
Heads,cam, bolts on, NA stock short block. Not a fancy race engine, stock intake, TB, rocker,lifters, WP,ect.
Ive seen fast intakes (over stock) gain less back to back on the same dyno!
These are $70
$70! best bolt on per HP ever,
Old 05-01-2014, 10:18 AM
Mike Morris's Avatar
LS1Tech 10 Year
I just ordered one on Ebay and didn't see this thread. Oh well. Look forward to trying it out along with the baffle.
Old 05-01-2014, 12:49 PM
LS1Tech Sponsor
ImprovedRacing's Avatar
LS1Tech 10 Year
Originally Posted by studderin
These work!!!!
These are $70
Nice! How much did you gain? If you could send us a before/after dyno chart that would be awesome.
__________________
Call Us: 407-705-3054 MON-FRI 10am-6pm EST
Like Us: Facebook - Twitter - Youtube
Old 09-27-2014, 09:31 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Reviving this thread as I'm curious about it for a 4.000" stroke as well.
Old 09-28-2014, 11:36 AM
LS1Tech Sponsor
LS1Tech 10 Year
We just moved so all of our development projects have been on hold for a bit, but we will be getting to the 4.000" stroke crank scraper very soon. We have a 4" Manley crank and rods we will be using to develop it. We'll keep you guys updated.
Thanks!
__________________
Old 09-28-2014, 12:32 PM
Super Hulk Smash
JakeFusion's Avatar
When I swap to a tubular K setup, I'm dropping my pan and adding the scraper and baffle. Wish I had added the baffle when I had the motor apart earlier this year, but the scraper wasn't available. This looks to be a very worthwhile upgrade.
Old 09-28-2014, 01:23 PM
1FastBrick's Avatar
Any future plans to make them for LS2/LS3 applications??? Or motors from 2005 and newer with floating pin rods???
Old 09-28-2014, 01:40 PM
Super Hulk Smash
JakeFusion's Avatar
I think the scraper is made for them as well. If you look at the site, they have them for Gen IV/aftermarket rods. I was looking at those a few minutes ago.
Old 09-28-2014, 02:40 PM
maroonls1z's Avatar
About to finish up my 4.0 stroke motor and would love one of these! Keep us updated and I'll be the first to test fit it on my Callie I beams
Old 09-29-2014, 03:59 PM
LS1Tech Sponsor
LS1Tech 10 Year
Yes, as mentioned, we've updated the design recently to accommodate the Gen VI motors as well. At the moment we only have them available for the 3.622" stroke motors, and they won't work with forged crankshafts like the LSA crankshaft.
__________________
Old 09-29-2014, 04:03 PM
Super Hulk Smash
JakeFusion's Avatar
Which one would I need to order if I'm using a Gen III crank and rods but with ARP rod bolts? The Gen VI scraper?
Old 09-29-2014, 05:14 PM
  #32
LS1Tech Sponsor
LS1Tech 10 Year
If you have ARP rod bolts, they will rub on both the Gen III and Gen IV scraper because they're a little taller than the stock bolts. We plan on adding more clearance on the next batch we build to accommodate this. However, you can just take a file and grind a little bit of material off the scraper where it rubs.
That said, if the only aftermarket part you have are the ARP rod bolts, you should use the Gen III crank scraper because it will contour the crankshaft more closely (specifically the rods and the counterweights) than the Gen IV scraper.
__________________
Old 09-29-2014, 08:06 PM
  #33
Super Hulk Smash
JakeFusion's Avatar
Okay good deal. I'll be ordering in a month or two. So I'll wait for the next batch.
Old 09-30-2014, 12:57 PM
  #34
LS1Tech Sponsor
LS1Tech 10 Year
Sounds good.
Looks like we will actually be releasing a completely different crank scraper for ARP main studs and rod bolts. The ARP main studs are bigger than the factory studs, so they won't be compatible with each other. We'll let you guys know when the new scrapers are available.
__________________
Old 09-30-2014, 03:40 PM
  #35
Jase01's Avatar
Plus aftermarket rods as well as main studs?
Sooner rather than later please.
Jason.
Old 10-04-2014, 11:34 AM
  #36
1FastBrick's Avatar
Great! In for the new updates.
Any chance you will get a picture of a GenVI style when you test the new designs to clear the ARP bolts?
Old 10-04-2014, 12:16 PM
  #37
UNDER PRESSURE MOD
Yeah, it has to clear forged rods and ARP bolts because those are the guys who are concerned about their bottom ends.
Old 10-06-2014, 09:27 AM
  #38
LS1Tech Sponsor
LS1Tech 10 Year
We'll post up with pics as soon as they're ready!
The new scraper will be designed for:
- 4.000" stroke with aftermarket rods
- ARP main studs
- ARP rod bolts
We will continue to make a scraper for the 3.622" stroke factory bottom end. Does anyone see a need for a scraper for the factory 3.622" stroke with ARP studs and rod bolts?
__________________
Old 10-06-2014, 03:30 PM
  #39
MMorgan9812's Avatar
Yes for us guys who like to use ARP studs and rod bolts with forged 346/347 setups. Please!!
Old 10-06-2014, 07:20 PM
  #40
maroonls1z's Avatar
Looking forward to the 4.0 stroke forged bottom end scrapers
Quick Reply: Improved Racing Crank Scrapers
