Oil pump install question...
So I am putting a high volume oil pump in my LS1. I am at the point where I need to lower the oil pan but I am having problems breaking it loose. I have all the bolts loose on the bottom, but I didn't take them out completely. Do I need to take them out in order to break the pan free? How much force does it take to break free? I am afraid to pry on it too much so I don't damage it. There are a couple bolts in a really hard to reach spot so I am trying not to remove all of them. Thanks in advance for your help fellas.
there are some that are underneath the k-member that are a bitch to see and to get too. i have to use a ratcheting wrench to get to them. i would just remove the bolts all the way. the pan doesnt drop down very far though. when you are working on the oil pump shove some paper towels or rags in the oil pan so if u do drop something in there it falls on the the rags and not all the way in your oil pan.
