How can you tell if your oil pump oring is installed correctly?
Old 03-05-2014, 11:36 AM
VerdeZ28's Avatar
Default How can you tell if your oil pump oring is installed correctly?
Ive been on here for a while discussing my heads and cam swap on my 2002 z06. its been done for a while and now im waiting on getting it tuned.
I had an issue with oil pressure and after installing a mechanical gauge it turned out to be a bad oil pressure sending unit, but im still a little paranoid so i was hoping you guys can put me at ease.
the oil pump is a melling 10295 high pressure. at cold idle its at 60 psi. once it warms up its around 50-55 psi. this is on the mechanical gauge.
if i had a pinched o ring would it be reading this high?
Old 03-05-2014, 12:20 PM
mchicia1's Avatar
You're fine.
Old 03-11-2014, 12:46 PM
Streetlegal?'s Avatar
If you had a pinched o ring it would be low. You are good to go
Quick Reply: How can you tell if your oil pump oring is installed correctly?
