6.0 head studs
Old Mar 10, 2014 | 11:20 AM
naparker1's Avatar
Default 6.0 head studs
Has anyone used the ls head stud kit from kmj performance or the eBay ones? Im building a 6.0 and wondering if I can use these.
Old Mar 10, 2014 | 05:23 PM
Werewolf SS's Avatar
Plenty of people have with out issue. IT was a hot topic when they first came out, but the general consensus is that they work just fine and have been in many high hp motors with lots of boost and no failures. A few have broken on initial install but this was most likely user error.
I have a set I just put on mine. Screw the studs in, use a allen key to give them a snug (not tight tight just a good snug) into the block. Then mount your heads as you normally would and trq the nuts down to 65lb tq. Doing so in 3 increments across all nuts. 20lb, 40lb, and on final pass 65lb.
Make sure you get the right one for your block. Their is two versions based on year block, 03 and below used a 3 bolt length setup while 04 and up used a 2 bolt length setup.
Old Mar 10, 2014 | 07:04 PM
COSPEED2's Avatar
LS1Tech Sponsor
Plenty of people have use them WITH issues as well. There are quite a few bad threads about them also.
We do sell the Pro Comp And the ARP. But honestly why by a poorer quality head stud, when a reg high quality head bolt or even a stock head bolt will work? You know how many stock JY engines have been pushed hard with stock head bolts? If you want to qualify a fastener like that, then just use stock. They will likely be just as good as the lower quality ones.
Old Mar 11, 2014 | 08:55 AM
naparker1's Avatar
Default studs
Thank u so much for input.
Old Mar 11, 2014 | 08:56 AM
naparker1's Avatar
Will prolly just buy some arp head bolts
Old Mar 11, 2014 | 05:51 PM
COSPEED2's Avatar
LS1Tech Sponsor
We've got em with free shipping! Check out the site!
Old Mar 11, 2014 | 05:53 PM
Atomic's Avatar
I need a gauge for that
If ya want to put things in perspective, price out some ARP CA625 head studs, 234-4313
Old Mar 11, 2014 | 06:24 PM
LS1MCSS's Avatar
Holy **** Batman
Kit #: 234-4314
Jobber Price*: $1000.16
