Stock '00 LS1 cam specs
Originally Posted by matt_h
198/208 .500' lift. Found this at <www.ls1howto.com> under cam install.
I just looked up those specs; it was the 01 and 02 fbodies that have the truck cam, but fbody LS1's have always had slightly different cams that Corvettes:
stock LS1 cam '98-00:
202/210 intake/exhaust degrees duration
.496/.496 inches lift
116 LSA
stock LS1 cam '01-02:
198/197 intake/exhaust degrees duration
.478/.478 inches lift
115 LSA
116 LSA
115 LSA
116 LSA
115 LSA
116 LSA
115 LSA
I really gotta replace that
This info is incorrect
116 LSA
115 LSA
here is the correct info as spec'd by a $250,000 machine at Comp
stock 98 trans am cam
duration@.050 198.86 intake 209.25 exhaust
lift .498 intake .497 exhaust
LSA 119.45
stock 02 trans am cam
duration@.050 196.37 intake 208.72 exhaust
lift .464 intake .479 exhaust
LSA 115.92
116 LSA
115 LSA
LSA 119.45
LSA 115.92
