Poor Gas Mileage After Move?
Hey all,
I have a 2002 SS Camaro with bolt ons (Headers ,Exhaust, Intake, etc) that I recently moved from Denver,CO to Tulsa, OK with. That being said I have lost a bunch of MPG since move. I have also gained quite a bit of power from leaving 6300FT at my old home.
The car in CO would get 24-27 City in Denver with moderate driving. The last couple tanks I have gotten 16-18 and that is totally babying it. I literally probably am not seeing 2.5K on the tach except if I need to pass etc. I dont have a check engine light etc though its just getting bad gas mileage.
I tried cleaning the air filter and also the Maf with Maf cleaner and used some top end cleaner for the motor and saw maybe 2Mpg better but its just been horrendous I have been riding my motorcycle to save money on gas.
Car has 40K on it and 23K on this motor. Where should I start looking? I am using 91 Octane gas. It does smell slightly rich but it has always been that way and I dont see alot of soot etc on the pipes like its crazy rich but the MPG is a mess. It does idle a little rough. The RPM needle is rock solid but it lopes a little at idle, nothing major.
Thanks for any help!
I understand that I will lose some due to the power/alt. But does 16 MPG seem right on an LS1 at sea level?
I guess I will try and find a tuner here in OK.
I had a Saturn SL2 that got something like 55mpg in Colorado. Just a side effect of the altitude. I average 21-23 with mostly highway driving at sea level in mine. Oh and don't baby it, every time I do that to mine, my MPG goes down to 19....
LS1Tech Premium Sponsor
Just a suggestion, but you might try unplugging your negative battery cable for 30 minutes and then reinstall to reset. This way the computer will relearn the new altitude change. It's free to do and may make a difference. If that doesn't do it you may look at a new tune but you will typically get better MPG at higher altitude due to the thinner air and not being able to make as much power. When I lived in Oklahoma 16-18 was about average for city driving in my stalled Trans Am.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
On topic though, in mixed driving my 00 ta m6 with bolt on mods in sig, achieved a max of 27mpg straight highway in ohio cruise @70mph. And fluctuates 17-20mpg in my mixed driving loop to work. So I see no issue with 18mpg in mixed w/boltons.
