Trickflow 215cnc heads and prc valve springs?
LS1Tech Premium Sponsor
Yes sir, those springs will work with the 215 set up. Is there a reason that you're considering the .675 spring kit over the .650?
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Your valve will not be opening to theoretical lift as a result of deflection in the push rods,rockers, and valves. A dial indicator at the retainer will in most cases be .015"-.025" less.
Lonnie
__________________
