Ls6 arp rod bolt torque confusion
Old 08-26-2014, 10:28 PM
ls1guy1968's Avatar
Default Ls6 arp rod bolt torque confusion
So I got the arp rod bolt set and was wondering what the correct torque should be. I know stock is around 16 plus x amount of degrees but the arp bolts in the supplied directions says 44 ft lbs. that's over double!? Is this correct I feel like it's going to strip the threads in the rods please help!
Old 08-27-2014, 02:35 AM
KCS
Moderator
KCS's Avatar
Yeah, torque it to stock specs. It's not like ARP knows what they're doing...
Old 08-27-2014, 06:32 AM
That's MISTER MODERATOR
Paul Bell's Avatar
If you don't have a rod bolt stretch gauge, depending on which kit you have, the rod bolts should be torqued to 40 or 45 ft-lbs. No need to worry about angles.
Old 08-27-2014, 01:03 PM
garygnu's Avatar
were your rods resized ?
Quick Reply: Ls6 arp rod bolt torque confusion
