to high of compression if...
Old 05-24-2004, 02:41 PM
dubrado's Avatar
Default to high of compression if...
I have a truck 5.3, but want to swap blocks for a 5.7 ls1 block...and since the 5.3 heads raise compression for you ls1 guys, I was wondering how high compression would be....
Will I have to retard timing at all?
thanks for your help guys.
Old 05-24-2004, 03:01 PM
bad2000ss's Avatar
Stock 5.3L heads on a Stock LS1 I believe will put the compression right at 10.7:1.
Old 05-24-2004, 03:21 PM
dubrado's Avatar
will I need to retard timing or anything?
Old 05-24-2004, 05:32 PM
dubrado's Avatar
bump ttt
Old 05-24-2004, 05:35 PM
jrp
SN95 Director
jrp's Avatar
for 10.8CR you'll be fine.
