ls7 heads on MID sleeved ls1 block with 4.155 bore??
Ok so Ive been reading a bunch on this site and others about the ls7 heads not working on ls1 blocks because of the bore, but my question is related to the valvetrain geometry as well as the push rod, lifter, rocker arm geometry of putting ls7 heads and intake manifold on an ls1 block with sleeves and a 4.155 bore.
What needs to be ran to make this setup work and is it even possible since my bore is in fact big enough now? seems like a great price since used ls7 heads go for under a grand used compared to other aftermarket heads. I've heard about problems with ls3 heads as well with the rockers being offset and that's another reason they won't just bolt on but I'm wondering if I can purchase proper valvetrain and lifters/push rods to make ls7 heads work on an ls1 block.
any help and insite is appreciated.
I myself didn't pay for the sleeves I bought the block already done for a heck of a lot cheaper than it would cost to do it so that's why. Now I have much stronger sleeves and I'm not limited on heads or valve size. I personally wouldn't spend the money to have it done but I got a good enough price that it didn't make sense to buy an lsa or lsx block over this one.
I've also ran plenty of MID sleeved motors on the street with 0 issues so I wasn't afraid of this one
I asked Steve at RED about doing this to my LS6 block and he wasn't keen on it AT ALL for a street car.
Thought I read somewhere that the LS 6 block is less desirable to sleeve than an LS 1,2, or 3 due to the lower end webbing having less strength. Larger ventilation (bay to bay) breathing for the higher strung ZO6. Remember most of GMs early testing was done with iron blocks as they were constantly exploding the aluminum ones due to the excessive inter bay pressure which was solved by the bulkhead vent holes.
ok well I guess Ill start tracking down a set of ls7 heads for the new setup since nothing else comes close in flow for the price. It will be nice too because I can use a stock ls7 intake manifold
The main thing I was worried about is the rocker arm/lifter pushrod geometry
Whoops, just realized it was a 4 year old thread. But yeah I'd be interested to see how OP's build is holding up.
