what do you recommend on my build
So I'm building a new motor for my car. I pick up an ls1 short block for a good deal. Scat forged crank, forged main caps, scat forged connecting rods, wiseco flycut pistons -5.7cc . What does everyone recommend for the rest of the build. Wanting to stay NA. I have a set of 243 heads and stock ls1 heads of they will be good with this setup
What's your goals for the car? Is it a daily driver ? What transmission you running ?
Super Hulk Smash
I'd point you to Tony Mamo. He can port your 243s or set you up with some of his new castings and a mild cam. But he does the whole combo and it works and will drive like stock.
Not to speak for him, but he'd probably set you up with a 227/231 114 camshaft or similar, worked heads (243s or his 220s), worked FAST intake, ARH/Kooks/LG headers, Johnson lifters, Manton pushrods, and YT Roller Rockers. He also will optimize quench and other areas of the build for throttle response and power.
Shoot him a personal message. His forum name is Tony Mamo and you can't go wrong with his work.
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
