LS1 Grand-Am Cup Cam, 239/251
Old 05-31-2004, 07:40 PM
GTS346's Avatar
Default LS1 Grand-Am Cup Cam, 239/251
Has anyone here used the LS1 Grand-Am Cup, 239/251 Duration @ 0.050, Racing Camshaft. What hp does this make with head work?
Has anyone used it without headwork?
Old 05-31-2004, 07:49 PM
M6HuggerSS's Avatar
what are the complete specs on that cam? thats a hole lot of duration!!!!
looks like track only 4000-7000 rpm cam?
Old 05-31-2004, 07:53 PM
Bink's Avatar
239/251, 0.570", 106 lsa
I have it in a stock bottom end 346. SCCA/LPE/LS6 heads. It requires flycutting/notching the stock pistons.
42# GM-Bosch Injectors. Bought the Cam and Heads from SDPC. With an LSX 90 mm intake and Longtube headers. It put down 444 RWHP and 402 RWTQ through 4.10s. And many a "Tuner" told me it would NOT make decent power - when I bought the parts 18 months ago. Not bad for off the shelf parts and a low lift cam.
There are better, more powerful, cams available now - and they are easier to tune I believe. This one is open loop and was difficult to tune with fly-by-wire ( It would have been impossible for me to tune without NoGo's help ).
joel
Old 05-31-2004, 07:59 PM
Camaro01SS4life's Avatar
My buddy has it on his WS-6, with stock heads...I think he put down 370ish to the rear wheels in an A4...It's not a very friendly street cam but then again what is friendly ...I think that cam has a 106LSA...Since vacuum pressure isnt that high during low RPM he has to put the car in neutral, rev it up, then apply the brakes when he is commin to a stop ...
Kevin
Old 05-31-2004, 08:04 PM
jrp
SN95 Director
jrp's Avatar
joel
do you have the dyno of your setup? dont remember seeing it in your old thread.
Old 05-31-2004, 08:56 PM
Bink's Avatar
Yeah, I just got it last Thursday nite. I'll scan it and post it tomorrow. Unfortunately they didn't plot my AFR ...oh well.
joel
Old 06-01-2004, 09:33 PM
Bink's Avatar
jrp - here's the sheet :
This is installed straight up - ICL @106.
I questioned the cross of HP/TQ not at 5252...they ( Phil at DynoTech Eng.) said it happens with the print out. I also checked with NoGo and he gave several reasons we could see this with Dynojet printouts. FWIW.
joel
Old 06-01-2004, 10:14 PM
Nickn20's Avatar
nice TQ band
i guess heads really help the car 370rwhp for that cam only is just garbage for a cam that big.
Old 06-02-2004, 12:51 AM
jrp
SN95 Director
jrp's Avatar
damn, i bet from 4k on its "hold on to your butts "
Old 06-02-2004, 07:49 AM
Moderator
John B's Avatar
They would if your scales on each side of the graph were scaled the same!
Old 06-02-2004, 11:05 AM
Bink's Avatar
Oh...........................................good point!
joel
Quick Reply: LS1 Grand-Am Cup Cam, 239/251
