Auto cars with the TSP 231/237
LS1TECH Sponsor
after looking over your mods Id stay stick with a smaller cam...even the tsp 225 i think would do a good job and give you a good amount of lope. With your size converter I just dont think it would be a great match tq wise and you'd probably be better off going a little smaller with faster rate ramps on the lobes. That cam would probably make as much if not more tq especially down low then the 231/237 JMHO.
LS1TECH Sponsor
Originally Posted by 99PewterZ28
Well I have already ordered it... I am going to get it tuned... I was just curious how bad it was going to be. BTW did you drill the hole in your throttle body bigger? Or would that even help?
Thanks for the advice. But for some reason after I heard my buddies car Ive been hooked on the TSP 231/237.. I know that you can get smaller cams to idle like this one... But Ive also reads the #s on the cam... & I had to have the biggest one I could buy without buying new pistons & etc.
LS1TECH Sponsor
My car drives pretty good on the stock tune with that cam. I had to drill two holes in the throttle plate and play with the idle screw a bit but now it's okay. It doesn't like hot start-ups but other than that driveability is fine for me. I'm sure it's running rich and down on power without the tuning but for now it works. Good luck.
Jeffrey
Jeffrey
Running 231/237 on home tune with edit , idles great at 650-700 hot /cold. only problem some surge/jerk at 36-41 mph ( can not understand which/how to adjust for this ) friend adjust tc lockup to stop problem for now , but must be better way
LS1Tech Premium Sponsor
I am running this cam and on a stock tune it would suck. A good tune is definitely helpful with idle and surging. Jason did my tuning and of course did a great job. I put down 377RW on the last dyno. You can get away with 3.73's and a 3500 but if you spend a lot of time at the track, you should think about going with a larger stall. Shift extensions will be higher and you will take better advantage of the power your making.
Brian
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
Texas Speed & Performance
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
A mail order tune is $250. Jason's done plenty of 231/237 cams, so he should have no problem getting you fixed up.
Brian
Brian
__________________
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
