torquer v4 cam or v2
hello there i'm new to this site wanted advice on wich cam to put in 01 trans am car is down due to cracked flex plate wanted ms4 but i think that may be to much how good is the torquer v4 or v2?
LS1Tech Premium Sponsor
Give us a call. We would be happy to point you in the right direction for your goals and combination.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
what gear ratio +oil pump
wanted to find out what gear ratio my automatic 01 TA has? Also do i have to change the oil pump when i go with torquer v4 cam
your A4 is probably 3.23. When it comes to cam selection, if you're going cam only, with maybe some headers, exhaust etc, I would look at TSP 228R, Ed Curtis Streetsweeper HT, or Martin Smallwood's SNS stage 2. I'm saying this because you're pushing around a 3600 lb car and need all the torque you can get. TSP's customer service is second to none. Call them up and you'll see. You can get a big cam with a name like LS godzilla and make it a dyno queen but your buddy with a terminator cobra is going to embarrass you. I've seen it personally. Do your research on valve events and keep your IVC around 42-46 ABDC at .050" if you're staying at 10.1 to 1. I'm no expert, but that's my $.02
Stall will improve et more than gears. If you have 3.23s I'd just stick with them and go with a good 3600+ stall.
I made the mistake (being used to manuals) and had 3.73s put in my car and now I have a whiny rear that really didn't improve the car all that much. A higher (numerically) gear with a stall will make it feel tighter from what I understand.
The 228R is a great shelf grind, one of the best! Do not entirely rule out consulting one of the vendors and see if they recommend a specific grind that will work best with your current setup and goals.
Moderator
Received 1,852 Likes
Lift the rear axle. Trans in neutral, brake off. Mark a wheel. Spin drive shaft by hand. If you spin the drive shaft 2-3/4 turns to rotate the wheel once, it's a 2.73. If it rotates 3-1/4 to one turn on the wheel it's a 3.23. If you get closer to 3-1/2 it's a 3.42. Etc
I love my v2 but I have a 4000+ stall and a good tune. Pulls good up to 6800 and never bucks or any problems with drivability. I also have a forged bottomend and prc stage 2.5 5.3 heads with all the boltons. Even with a auto and big stall 400+hp is achievable with it.
I've seen 315 wide on stock rims but it looks like it's pushing it. I have always had horrible luck with nitro 555r and nt05.. I was hooking well with mickey Thompson et drag radials.. they don't last as long but way better.. you end up choosing a cam? I've been eyeing the v4 pretty bad.. it's always a hard choice with so many opinions and favorites on here. So many great possible choices though.
