Howards cam 5.3 226/232
I have a chance to buy rods, cam, spring and all that for 400 with an Howards cam specs 262/232 .578/.587 . Has anyone else ran this or used it? Any good?
It's a 01 Silverado 5.3 extended cab 2wd short bed with 3.73 auburn locker in it with stock converter but shift kit Transgo hd2 with longtubes 1 3/4 to 3 in all the way out. Then it's tuned too but mostly stockx
That much cam and you are going to need a high stall say 3000minimum to work right.
If your friend claims it works well in a similar application but with a 4.8l then he just doesn't know any better.
In a 5.3l that is getting aggressive and with stock gears and stall probably looking at 30mph before it wakes up.
I would think the 218/223 would be better, personally. And especially since you have the stock converter. I think you would like the wider LSA on the Brian tooley cam for daily driving, too.
With the stock converter, I think you will see more appreciable gains from the Brian tooley cam, longtubes or not. Don't get me wrong, the exhaust will definitely help.
Either cam should give you a noticeable difference, especially when combined with a full exhaust, but the smaller cam is a better match, in my opinion, and will provide you with a better driving vehicle.
