Copper RTV in combustion chamber?
I have to replace my cam again, and got to wondering if I need to take the intake off again?
I used copper RTV on the intake rocker bolts, so I'm assuming some will fall into the intake port and then the combustion chamber. Will it just burn off? Or should I remove the intake and vacuum it all out.
You won't need to remove the intake manifold to change the cam. You will have to remove the rockers arms to relieve tension on lifters and cam - you knew that - but the post above sort of confused the issue. I haven't heard of anyone taking any special precautions about any RTV sealant that falls into the combustion chamber. I'm sure others will chime in.
Moderator
Received 1,852 Likes
RTV is no big deal in the combustion chamber. It'll burn off. It is known to foul oxygen sensors so after the cam swap, when you go to get it tuned, don't be too surprised if the tuner tells you the oxygen sensors are a bit lazy
Just my personal opinion, last time I had a situation like this I pulled the intake so I could put rags in the intake ports prior to pulling the rockers. Then I used a powerful shop vac with the small fitting to vacuum out each port. Just something I felt more comfortable doing to prevent anything from going into the cylinders.
why wouldn't you need to remove the rocker bolts if you are replacing the cam?
