99 Camaro ls1 rebuild piston to cylinder clearance ?
I spun a rod bearing on my ls1 so I am getting the crank cut and all new bearings and rings. After honing the block the piston to cylinder clearance is 0.004. Is that OK for stock short block with 595 605 lift cam and ported 243 heads
