It happened,....yes again
Ok my car spit up some needle bearings in the oil a while back and I knew exactly what it was. So far about 20 of the bearing had been recovered. Well my car is at the shop getting some stuff done to it, and while its there i have em go ahead and change the oil while therye under the car anyways. Then I get a call saying that is bearing in the oil, I think its just the rest of the ones I never found. When I get there come to find out they pulled a good 23 of em out of the oil, so this means that another one decided to spit up on me. What options do I have for better rockers. These are the 98 style heads and I really dont feel like putting a new set of heads on the car. Least not now anyways.
The Harland Sharp rockers fit under the stock valve covers the 98 requires some grinding. Here are some pictures to help you out. I have replaced dozens of these for this reason.
NAte
NAte
You know I was just looking for your number to call and ask you that smae question. Thanks. Ill see what my expenses will allow me to do in the next couple of days.
