Possible to get a borescope to lifter/cam lobe?
I don't think I could see much with my home borescope, but the one I used to borrow from work that had an articulating head the would rotate 90 degrees and used a laser for a light source might do it. I agree, valley cover is really the only easy path.
Have you listened with a stethoscope? Can you narrow it down to one of the front or back cylinders? If it is, the chances of successfully using the scope will be much better.
