Note on Morel Bushing Lifters/Mamba's/Needle Bearing.....
DO NOT CLEAN WITH SOLVENT BEFORE INSTALLATION. USE OIL ONLY AND A LINT FREE TOWEL.
Needle bearings have a high pressure grease that is used during assembly for initial break in. Solvent will remove this.
Bushing and the Mamba's have an applied dry film lubricant for break in. Solvent will remove this.....
Wipe lifters down with lint free towel and soak in engine oil of choice. The oil you are using for break in is a good choice.
On the bushing and Mamba's. Break in procedure. Run the engine for 20 minutes with no load from 1800 to 2200 rpm. No higher.
