Here are a couple new products that keep unfiltered oil out & improve flow!
Old 03-16-2017, 06:16 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default Here are a couple new products that keep unfiltered oil out & improve flow!
SacCityCorvette's
Precision LS Billet Barbell and other Oil System Improvement products!
The Oil Galley Barbell in your LS based engine is something that is over looked. And yet it serves a very important mission of directing oil to the oil filter. If oil leaks past the Barbell it will go unfiltered directly to the Cam Bearing, Lifters, Crank and Rod Bearings. (See Diagram Below) The factory Barbell is approximately .020” to loose so particles as big as 500 Microns can leak past the factory Barbell. Your oil filter will filter out 15 to 25 Microns depend on the brand of filter. Our 7075 Aluminum Precision Billet Barbell fits with approximately .001” clearance which will let only about 20-25 Microns pass by, that same as the filter.
Another important part is the shaft of the Barbell. The oil has to flow around it to get though the oil port. Our Billet Barbell has a 30% smaller shaft for much less flow restriction.
We have also added a 1/4-20 threaded hole in the end of our Barbell for easy removal. Just screw a 1/4-20 bolt in and pull the barbell out. No more digging and prying to get the factory one out.
Better engine protection from much less and smaller particles bypassing, smaller less restrictive shaft for better oil flow, replaceable High Temperature Viton O ring and for ease of service a threaded 1/4-20 hole.
Why would you ever put the plastic factory Barbell back in your expensive LS engine build?
See Our other Oil System Performance Improvement Products below.
Fits LS1-2-3-6-7-9-LQ4-LQ9-4.8L-5.3L-6.0L-6.2La and more! Also available for the new LT1/LT5
Only $26.95 Free Shipping
http://www.saccitycorvette.com/Billet-BarBell.html
Here you can see how the unfiltered oil gets by the loose factory Barbell. Also you can see how our Barbells smaller shaft will improve oil flow!
Check Out all 4 of our Oil System Improvement products!
If you don't know much about how the Barbell works check out video.
Video of how loose the factory Barbell really is compared to our billet Barbell.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 03-16-2017, 06:21 PM
07NBSChevy's Avatar
Sweet, I may have to pick up the bypass plug. I like how you look into improving things that most people overlook.
Old 03-17-2017, 12:04 AM
BlackDuk98's Avatar
Very interesting product. May pick both of these up, but would wait till next time I tear the motor down to install the barbell part. I own the front and rear cover alignment tools from you guys and absolutely great product. Works perfectly.
Old 03-17-2017, 09:09 PM
LS1Tech Sponsor
Thanks 07NBSChevy and BlackDuk98 for the kind words and business!
Christian
__________________
Old 03-20-2017, 11:19 AM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Have you verified the pressure differential on either side filter with each version of the barbell? I'd be curious to know what the pressure drop is (if any) on the outlet side of the filter.
The bypass delete makes good sense.
Old 03-20-2017, 01:16 PM
LS1Tech Sponsor
Hi mOtOrHeAd MiKe,
No we haven't checked the pressure diff. That would be interesting though.
But the oil pressure would be a little lower just because of the restriction of the filter element. And the finer micron element the more restriction. Also after the oil comes out of the filter it has to pass through several 90's (see diagram)that would drop pressure even more and if you run a oil cooler even more drop. Also when the oil comes from the pump and hits the barbell (circled on diagram) and makes a 90 down to the filter that would create a high pressure area that would allow oil the push by a loose barbel. Even if its a little lower after the filter, oil will go pasted the stock barbel. Anyway that's how I see it.
__________________
Old 04-28-2017, 01:58 PM
LS1Tech Sponsor
Our Billet Barbell oil diverters are now available for the new LT1 &LT4!
http://www.saccitycorvette.com/Billet-BarBell-LT1.html
__________________
Old 04-28-2017, 04:03 PM
RollingDumpster's Avatar
I bought one of your oil filter bypass plugs but I cannot figure out an easy way to get the OEM unit out. I unscrewed the filter adapter but there is no easy way to pry it out. I assume it is pressed in and I cannot get to it from any other angle to punch it out. I almost need a tiny slide hammer. Any tips?
Old 04-29-2017, 09:21 AM
That_One_Person's Avatar
Friend has an oil barbell in his SBE big cam LQ4 build we're trying to piece together. It looks like a piece of art compared to the stock unit. Makes you wonder what GM was thinking. I'll be buying one in whenever I put a built transmission in my car!
Old 04-29-2017, 12:36 PM
LS1Tech Sponsor
Hi RollingDumpster,
Thank you for your business!
It is somewhat of a pressed fit but not super tight. I used a easy out and was able to twist it out. I suppose if you get the right size screw or bolt and get it screwed in then use vise grips to wiggle it out or slide hammer would work great if you can get it hooked up. Also using a chisel to dent the edge inward might help relieve the press fit and loosen it up. Its one of those things that you just have to work it.
__________________
Old 06-12-2017, 04:09 PM
pantera_efi's Avatar
Default Oil Pan Flow Modification
Hi SaCity, good work.
I modify the Oil Pan (OEM GM) always for flow increase.
The Block passage ways are 2X the size of the passage ways in the Oil Pan.
All here can see this if they remove the Oil Filter Insert.
Your RED Flow Path shows that area, I use a 1/4" drill for the hole size.
I have made an Oil Filter Insert that allows the LONGER GM Truck Filter to be fitted, a good mod when the Bypass is closed off.
I would ADD the "tech" to warm the oil when the Bypass is closed, this is one reason it is there.
Lance
Old 06-27-2017, 05:47 PM
LS1Tech Sponsor
Thanks Pantera for the kind word!
Good job on the oil system mods!
Christian
__________________
Old 08-13-2017, 04:08 PM
sjsingle1's Avatar
I installed the bypass plug in my sons oil pan yesterday....little more complicated than just pulling it out....but its in now
when I do my oil pan I will make a vid for everybody to save time !
Old 08-14-2017, 10:23 AM
LS1Tech Sponsor
Hi sjsingle1,
Any pointers you can provide would be great, especially on video!
Thank you,
Christian
__________________
Old 08-14-2017, 10:54 AM
Default Oil Filter Magnet
Hi SJ, you could also install one of my Oil Filter Magnets. ($8.00)
This magnet will "trap" ferrous particles BEFORE they enter the Oil Filter.
THUS a longer filter life with EASY engine condition inspection when the filter is changed.
The size of the particle the magnet can trap is less (smaller) than 1 micron.
The magnet may be cleaned AND reused at each filter/oil change OR with good oil condition, a filter R&R could allow EASY engine condition inspection.
Lance
Old 08-14-2017, 03:17 PM
sjsingle1's Avatar
hay Pantera....I am all about magnets ! make a thread and post some pics
Old 11-18-2017, 10:36 AM
Hi All, most here state a HV Oil Pump is required, a Melling.
I fit the GM 2010 Camaro AL pump (native HV) for a cost of $90.00 AND modify the pan oil filter boss area.
When you fit a pump greater than the flow requirement, the oil flow recirculates internally inside the OP causing a Oil Temperature INCREASE.
All here can witness/inspect the block flow paths with NO report of the Oil Pan flow path inspection.
The Oil Pan flow path is ONE/HALF or less than the block Flow Path AREA.
This is called a RESTRICTION, that area reduction at the Oil Pan Boss/Oil Filter Insert.
My method to correct this is to first remove that insert then port that area AND ADD another passage way, a simple NO COST method completed in 15 minutes. (pan off car)
The picture shows that drilled passageway.
The engine HP will increase with this MOD
Lance
Attached Thumbnails Here are a couple new products that keep unfiltered oil out & improve flow!-dsc_0041.jpg
Old 11-18-2017, 10:21 PM
Received 3,394 Likes on 2,098 Posts
Lance
Lance, I agree with your findings. I always enlarge the oil pan passageways (port them) to make oil flow much better. I found this to be true with the GM pans, AND the Holley pans as well.
Old 11-19-2017, 03:07 AM
LS1Tech Sponsor
Hi Lance,
I agree with opening the pan ports on the pan up by porting. But it looks like you are drilling another port? Can you elaborate? Or did I misunderstand?
Thank you,
Christian
__________________
Old 11-19-2017, 03:09 AM
DietCoke's Avatar
Unfiltered oil, in the context you're using it here, is irrelevant.
Quick Reply: Here are a couple new products that keep unfiltered oil out & improve flow!
