need an early LS6 cam
Old 07-11-2004, 02:40 PM
derek_silvy's Avatar
Default need an early LS6 cam
Ok, I think what I may now do is get an earlier LS6 cam, as they are a little bit milder than the 02+ cam.
I can accept losing a little low end because within a couple months I will be buying a torque converter.
Does anyone have the cam that they would like to sell me?
I will also looking to buy some more springs. Some one is offering me some 918s for 100 dollars, but I think they are even better than the LS6 springs, which I don't know if I need. I'ld like to get some springs that will handle .550 of lift for cheap.
PM me if you would like to sell either the cam or springs.
Thanks,
Derek
Old 07-11-2004, 03:12 PM
cyphur's Avatar
you might be able to pick up some 915's, they are good for around .550...but ls6 springs are just a good peice of mind. they work great for the ls6 cams, and they last forever on it. why go any cheaper then that? you could prolly find a set for cheap on these boards. post a WTB in the parts wanted, and skim the For Sale section.
even did a search for ya...here are the results https://ls1tech.com/forums/search.php?searchid=504478.
Enjoy!
Old 07-11-2004, 03:55 PM
Thanks a lot man!
