Can someone help me out please. Need to get a Cam for these heads. What cam?
ARE stage 2 heads upgraded to stage 3,
2.055/1.60.
Flow #: Int/Ext
200- 140-117
300- 199-181
350- 228-198
400- 252-207
450- 272-211
500- 285-214
550- 299-215
600- 312-217
I have these heads. I am putting the motor into a 1993 mazda rx7. The car has a tall gear.... 3.90 and im running a 6speed tranny. Car weighs about 2600lbs - 2700lbs with the ls1 in it.
Im looking just to drive the car on the street and once or twice at the track.
Any one know a good cam for this. I want it pretty aggressive, but streetable.
2.055/1.60.
Flow #: Int/Ext
200- 140-117
300- 199-181
350- 228-198
400- 252-207
450- 272-211
500- 285-214
550- 299-215
600- 312-217
TT-TECH Veteran
I like most of the 224 cams for street cars other are running bigger but not as streetable IMO. Everyone has a different out look on streetable so remember that when people recomend other rather large cams I like FMS grind and I like the tried and true C2 tha MTI offers 224/581224/581 112+4. Should make real good power and will be very driveable. If you want more think about 228 range with @580-590 lift. Look around and see what the sponsers have to offer the MTI X1 cam is real popular right now so you could find one of those used for a great price. FMS gives a very detailed description of how there cams power ranges should respond in your car so does Thunder racing others you just might have to call to see what they recomend etc... Good luck! If you do a search you will find quite a lot on cams and opinions so use the search feature etc...
http://www.vincihighperformance.com/...%20LS1%202.htm the 047 would be a great choice for you. call (407)476-VETT and talk with joe vinci (sponsor here and board name as well).
SN95 Director
Originally Posted by KingCrapBox
As far as sponsors go, Steve @ Race Engine Development and Erik @ Horsepower Engineering will be able to match a cam for your combination.
