Are 2.055 valves to big for a stock bore 346?
Old 08-12-2004, 06:53 PM
carnorvor's Avatar
Default Are 2.055 valves to big for a stock bore 346?
Here is some heads I bought. He was running them on a 396 all bore. Will I have a problem with the bigger heads? Should I just not worry about them? Would I pick up more power going smaller valve?
ARE stage 2 heads upgraded to stage 3,
2.055/1.60.
Flow #: Int/Ext
200- 140-117
300- 199-181
350- 228-198
400- 252-207
450- 272-211
500- 285-214
550- 299-215
600- 312-217
Old 08-12-2004, 07:48 PM
C4VetteLS1's Avatar
they work great
Old 08-12-2004, 08:22 PM
Senior Member
Country Boy's Avatar
They work good
Old 08-12-2004, 09:22 PM
M6HuggerSS's Avatar
thats as big as you need to go! i got the same in my heads
Old 08-13-2004, 06:19 AM
TVWilkes's Avatar
2.055/1.60 valves work great in a 346.
Old 08-13-2004, 06:29 AM
99ta's Avatar
They prob flow to much you could just give them to me and I'll go ahead and give ya mine.... Anyway they should work great!
Old 08-13-2004, 07:56 AM
Ragtop 99's Avatar
The valve size is not the issue. I have 2.08/1.60s on my stock bore. If the heads you bought were on a 396 all-bore, then the combustion chambers have been opened up beyond the stock bore. You might ask whether that will have an impact.
Were the flow numbers on stock bore or the larger bore?
i'll have some ARE SII heads for sale soon if want some.
Old 08-13-2004, 11:26 AM
carnorvor's Avatar
Thanks. i will look into that.
Old 08-13-2004, 11:38 AM
cyphur's Avatar
like ragtop asked....what are the combustion chamber sizes? thats whats going to make the difference. the valve size is going to help you, not hurt.
Old 08-13-2004, 12:40 PM
8 Sec Tuner
Mike TexaSS's Avatar
What happened to keeping bore size and valve size proportional?
