installed heads and cam, QUESTION ON VACUUM???
installed cam, heads, now I have a large amount of crankcase vacuum at oil fill cap. IS THIS NORMAL, THANX. also deleted A.I.R. and EGR CAM SPECS 232 duration ,.598 lift 113+2 lobe center
yes it is plugged
I dont have a vacuum guage, but if i put my hand over the oil fill hole it sucks my palm enough so it makes a reasonably loud noise when i move it away, THANX
By plugged, I meant closed off. Did you re-connect it? or actually plug it?
Reason I ask is that hose is the other end of the PCV system. If no air is allowed to enter that side, then the valve side will continually suck down the crankcase...including the oil.
Doh!!!
I F'D up by plugging passenger side breather onto the port on the bottom of the pass. side of the intake instead of top pass. side of throttle body. DUMB ***. MY BAD BUT ALL FIXED
THANX
THANX
