What cam for LQ9 crate engine?
Old 08-28-2004, 02:05 PM
The Guy in MY 99TA's Avatar
Default What cam for LQ9 crate engine?
I'm thinking about buying a LQ9 crate engine and putting something like a 232/236 or some other big camshaft in it till I can get the money for a 408. But then again I might just build a turbo system and not do a stroker motor till way later.
What camshaft would you guys recomend?
Josh S.
Old 08-28-2004, 08:47 PM
TTT pwease
Old 08-28-2004, 08:52 PM
taqwache's Avatar
i would go with a t-rex.
Old 09-02-2004, 05:16 PM
TTT got 1 vote for a T-rex anyone else?
Old 09-02-2004, 05:17 PM
cyphur's Avatar
I'd look at some of Futral's cams. I read something about the ron jeremy cam(the cam's unofficial joke nickname). was a one off for either a major max effort 346 or a 408, i can't remember. it was wicked crazy tho. i think you could acheive some serious numbers with a cam like that. i'll go look for it and try and get you the specs.
edit: nm, i had thought it was bigger then it was. was only like 236/239 .601/.610 111lsa. i guess i was wanting it to be a bigger cam, lol.
i'd still talk to futral about a custom cam, but if you don't want to put that much effort into it, the t-rex is definitely a good cam for a 6.0L.
Old 09-03-2004, 06:37 AM
Sky042's Avatar
What about a MS3 for him?
Old 09-03-2004, 06:40 AM
jrp
SN95 Director
jrp's Avatar
how can one recommend anything with the little to no info you have given us?
Old 09-06-2004, 05:57 PM
What info do you want?
it would be an LQ9 crate engine(6.0 that came from the escalades and a couple other things I think). Just a cam only engine, with headers, ls6 intake, tuning, thinking about going back with a TCI 4000 converter, gunna do a 9 inch swap with a 3.90 gear and some 28 inch slicks. I am going to set up the suspension from there and work towards going fast.
Josh S.
Old 09-07-2004, 01:52 AM
jrp
SN95 Director
jrp's Avatar
Josh S.
that type of info.
since this appears a track prepped setup i'd go big; x2/x3, MS3, ect.
Quick Reply: What cam for LQ9 crate engine?
