Timing Chain
Old 09-10-2004, 07:32 PM
ls6jimmy's Avatar
Default Timing Chain
I have a ls1 engine but it had no timing chain and I'm wondering should I just use oem or go aftermarket; if aftermarket is the way what is a good name brand?
Thanks for any help
Old 09-10-2004, 07:53 PM
AnthonyR's Avatar
Go with a double roller, Rollmaster is a popular choice and available from SDPC
http://www.sdpc2000.com/cart.aspacti...2267&pid=90940
Old 09-10-2004, 07:56 PM
L.Lopez's Avatar
I agree.Use a double chain.
Old 09-10-2004, 08:03 PM
ls6jimmy's Avatar
thanks alot
Old 09-10-2004, 10:15 PM
PREDATOR-Z's Avatar
Which Cam???
No need to overkill, a simple J-wiss would do fine. Unless you'll have a radical cam.
Old 09-10-2004, 10:35 PM
cyphur's Avatar
Originally Posted by PREDATOR-Z
Which Cam???
or even a single rollermaster.
Old 09-11-2004, 12:56 PM
Orange Peel's Avatar
JWIS here, haven't installed it yet, but will work fine. Oh and I run a G5X3 cam
Old 09-11-2004, 08:33 PM
ls6jimmy's Avatar
224/228 567/571 114
Old 09-12-2004, 12:43 AM
PREDATOR-Z's Avatar
J-WIS will do, much easier to install, no need to remove crank sproket (unless damaged of course)
BTW I believe this is the chain they use on C5R "LE MANS" corvettes.
Old 09-12-2004, 08:28 AM
chris2000ss's Avatar
single JWIS chain here also!!! g5x3 cam
Old 09-12-2004, 11:28 AM
DrkPhx's Avatar
I use the GM heavy duty chain and it's plenty enough.
Old 09-12-2004, 04:29 PM
shaneSS's Avatar
J wiss. Its stronger than most and no need to machien the underrive pulley as with most double roller chains .
Old 09-12-2004, 07:40 PM
Quick 99's Avatar
jwis is a great chain
Old 09-12-2004, 07:58 PM
Cstick's Avatar
Where can you get this Jwis chain, and how much is it?
Old 09-12-2004, 08:26 PM
Quick 99's Avatar
thunder racing has it for maybe 150 im thinking?
Old 09-12-2004, 08:40 PM
01_SuperSlow's Avatar
JWIS here also. Very nice chain
Old 09-12-2004, 08:45 PM
That is correct, JWIS is the chain used in the C5R engine.
Old 09-13-2004, 11:12 AM
Cstick's Avatar
How much do you have to machine off your underdrive pully to use double rollers? Can a single roller Rollmaster be used without machining?
Old 09-13-2004, 11:18 AM
PREDATOR-Z's Avatar
Yeap, single no machining
