what cam for this?
what cam for this?
hey guys i have always liked that rough nasty lobe idle of fast old muscle cars.
what cam or combo would you need in a ls1 to duplicate that off-idle mean sound?
but still be streetable everyday. is there a fine line??
thanks for any info.
if you pick a cam based on sound alone don't expect it to perform as well. not that it won't, but like it was stated you should really choose the cam based on how you want the car to perform and what other mods you want to add later. Do a search. there are several cams that sound awsome and will work with a stock setup
i would say, if ur just going for sound, get the Hotcam... it will need tuning to be perfectly streetable, but so will any big cam... hotcam will go easy on valvetrain, unlike the big cams, and is reasonably priced... u can make big cams streetable, and make alot more power, but u will need to spend more on better springs and other hardware...
cam
I use this in my daily driver.
anyone have any links to videos of diff sounds with diff cams
so in traffic it would be a bitch your saying?
does it want to stall?
and how much gas milage do you lose with a diff cam and heads
thanks
thanks
