Main Studs swap, is it ok to do?
Old 10-04-2004, 07:48 PM
what a rush!
moregrip's Avatar
Default Main Studs swap, is it ok to do?
along the same lines as swapping out connecting rod bolts.
has anyone done this? I've got a Radix going on soon and would like to swap out the Con Rod bolts and switch to Main Studs for a little extra strength.
I doubt I'll rev past 6500rpm.......thanks
Old 10-04-2004, 08:31 PM
LOnSLO's Avatar
Main studs will be fine as is. The stock rods will give way before a cap will move on you.
Old 10-04-2004, 09:25 PM
Hysteria's Avatar
Be sure to have the block line honed after stud installation. Changing from bolts to studs changes the torque load on the cap and will throw the mains off.
