LQ9 / LQ4 6.0 oil change question - 408ci
Old 10-25-2004, 07:10 PM
MeanWS6's Avatar
Default LQ9 / LQ4 6.0 oil change question - 408ci
What oil filter do we use and how many quarts of oil for these blocks? Is it the same as the LS1?
Old 10-25-2004, 07:14 PM
LS1 Tech Veteran
Steve Bryant's Avatar
What oil pan is installed on the engine? That is the determining factor. The truck engines 4.8/5.3/6.0 and even a bored and stroked version with the truck pan would still be 6 quarts. Now if a pan is modified, that changes the equation, too.
If the vette or F Body pan is used, the oil sump capicity would not change either.
Old 10-25-2004, 07:39 PM
Dustin Butts's Avatar
I just get the filter for a late model 6.0 ltr truck and run 6qts of oil. I have the f-body oil pan.
Old 10-26-2004, 09:31 PM
383ss's Avatar
it is not the same oil filter as an LS1. use a filter for a silverado with a 6.0L
Old 09-07-2010, 04:25 PM
victor111262's Avatar
im using the ls1 oil filter and 6 quarts f oil
Old 09-07-2010, 07:33 PM
JP
JP's Avatar
same here
Quick Reply: LQ9 / LQ4 6.0 oil change question - 408ci
