Diamond (or other manufacturer) piston specs?
Does anyone have a PDF or similar of Diamond piston specs? Looking for some pistons for a 408 (4.030 x 4.000), and their website seems to be down. Who else makes LSx pistons? JE, Ross, Diamond, who else? Thanks, Shawn
You may want to consider the JE pistons. With your 4.000 crank the #8 piston will have to be clearanced. JE's will clear the reluctor wheel no problem, but if you get Diamonds then you will have to grind down one piston yourself. I may sell my Diamonds and get JE's just so I don't have to mess with it.
Under criminal investigation for fraud
JE's will clear but the forging they use is not that well suited for a power adder. Keep that in mind when buying. The Diamonds with the clearance in them can take a lot of abuse. Both company's make great pistons.
Thanks
Thanks
In my 4.030 x 4" 408, i had diamond do thiers with lowered ring stack, tool steel wristpins and triple thick deck.... If the tune is right they see a 400 shot being no big deal which i cant wait to get to spraying...
I can shift faster than you.
I have used both pistons in 408ci buildups. Both are very good options. I have used quite a bit more Diamonds though as their customer service is hard to beat and it is a piston we keep in stock.
Jason
Jason
