Tried to start car today after coil relocation, loud popping noises!!
Old 04-09-2003, 02:06 PM
quickWS6's Avatar
Default Tried to start car today after coil relocation, loud popping noises!!
I installed one side of the Jay Fisher coil relocation kit. I started working on the other side and slightly brushed a coil with a drill bit. So, I decided to start it up and see if everything is going good before I install that side. I hooked everything up, and as soon as I tried to start it I heard backfiring/detonation...a loud popping anyway. I shut the car off. This is did not happen before I installed the relocation kit, so I'm assuming it has to do with it. I also just put some gas in the car, but it was 93 octane, so I'm assuming it isn't detonation. What could it be? Any help is greatly appreciated.
quickWS6 is offline
Old 04-09-2003, 02:08 PM
quickWS6's Avatar
Default Re: Tried to start car today after coil relocation, loud popping noises!!
Also, when I got it to idle before, I heard a slight whistling sound at idle, but didn't notice it when I held it anywhere above idle.
quickWS6 is offline
Old 04-09-2003, 02:26 PM
GeorgeC's Avatar
Sounds like you may have those 1st four coils you did wired backwards... <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Double check everything.
GeorgeC is offline
Old 04-09-2003, 05:12 PM
blazinredls1's Avatar
on a sidenote, can you give us an install time on that kit and if its just a cut and dry install? Looks simple enough, pics tell alot.
blazinredls1 is offline
Old 04-09-2003, 05:21 PM
Jay 95WS6's Avatar
you reversed the coil connectors i did it the first time i did it too
Jay
Jay 95WS6 is offline
Old 04-09-2003, 08:46 PM
frcefed98's Avatar
Where can I buy one of these Jay Fisher Coil Relocation kits. I tried his homepage and it takes me to some generic webpage for autodealers.
How much $$ are they?
Thanks,
Jeremy
frcefed98 is offline
Old 04-09-2003, 09:18 PM
Camaroholic's Avatar
Email Jay (above in his profile) for ordering. He takes Paypal.
I bought his brackets. They look nice. Will definitely save me time and the hassle of putting it all together - knowing me, it'd take me 2 hours in Home Depot alone just to find the freakin' parts. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> The brackets are something like $49 or so.
I opted out of the coil wires, tho. Precut and assembled wires are $180 or so. I saw them on Jason99T/A's car this past weekend, they look *very* nice. But I'll roll my own.
HTH,
Andrew
Camaroholic is offline
Old 04-09-2003, 09:59 PM
quickWS6's Avatar
THanks a lot! I finally got it going good, but then when I changed the coils into the right position, it wouldn't start again. I must have turned the connectors around.
The kit is very nice. It's a bitch trying to drill through the brackets though, atleast with my tools. The only thing I would change is get some black plug wires and pre-drilled brackets.
quickWS6 is offline
Old 04-09-2003, 11:28 PM
quickWS6's Avatar
Does it matter what coil goes where, or just how they are wired up?
I realize this has become external engine instead of internal, so if someone can answer this for sure, I'll delete it or the mods can move it.
quickWS6 is offline
